Thermostat Filter Management?
How can I delete my added furnace filter under Filter Management?
I don’t know of a way to do it other than re-setting it and starting set up over again. Wyze should consider a future update to allow edit of the filters you have, add, delete, etc.
From Mark5 other another post:
On filter list screen, swipe left to delete. And you’re correct, doesn’t appear to have an edit feature. Delete and re-add.
Have you tried Swiping Left or Right? Some of the functions seem to follow the normal Mobile processes.
