Anybody have suggestions for hooking up an alarm/siren to dissuade intruders? If so, what hardware and how did you set it up?
Thanks! - Pete
Thanks! - Pete
Create some rules with some sensors and a plug.
I’d try wiring one of these to a Wyze plug:
https://www.amazon.com/Wired-Outdoor-Bracket-Security-System/dp/B07P1FNJTG/ref=sr_1_2?crid=KJ97HA7YS67E&dchild=1&keywords=12+volt+siren&qid=1597365527&sprefix=12+volt+si%2Caps%2C363&sr=8-2
And the required power supply:
https://www.amazon.com/inShareplus-Mounted-Switching-Connector-Adapter/dp/B01GD4ZQRS/ref=sr_1_4?crid=2ETSZDFIID57F&dchild=1&keywords=12+volt+power+supply+for+siren&qid=1597365645&sprefix=Siren+power+su%2Caps%2C289&sr=8-4
Thanks!
