Setting Camera operation schedule
I was trying to set up a daily schedule for our camera to start and stop working in a daily basis. I can’t seem to find that option in the app. Also, I tried sending a support message but I believe the workflow is not working to let you enter a message and submit. Any advice?
Hello @katia_pajares, for what you are looking for I recommend looking into IFTTT integration with your Wyze cam. I will link you to some videos and articles to get you started.
Edit: If you don’t want to go the IFTTT route then you can use the in app shortcuts which you can create for each camera individually at the top of the main home page.
Link to shortcuts
https://support.wyzecam.com/hc/en-us/articles/360015658451-Shortcuts
Wyze Integrations - Connect Your Apps with IFTTT
Links to IFTTT integration
