You just made my point. Good job genius!
I started the original thread regarding the DNS ping to China directly. I was assured by Wyze that the firmware and software teams are US Based and Wyze does not sell their products to China. Why are we still seeing a DNS pings to 114.114.114.114 with hardware products and mobile apps? I would like an executive to answer this question for the benefit of Wyze. This type of information that can hurt the reputation of Wyze and can be squashed quickly.
Seriously, it is a DNS server. You’re talking about a very old product and at some point it made use of that DNS (Wyze stuff is manufactured in China with “off the shelf” parts and drivers that are also made in China). Many of the older products were just “white labeled” products that were not even designed by Wyze, running code made by that manufacturer.
They’ve said they’re working on trying to remove that old code, but given the device is very old, and it may not be code they even have control over, it may not even be possible. If it is of concern to you, just block it.
Good luck with that.
It’s also the app on the phone itself, which was supposed to be addressed a couple years ago. So while it is a minor security issue with the DNS server. It’s that Wyze says they will address it but never do.
The app is basically just a “container” for each cam’s interface, so I suspect that is why it also sends queries to that DNS server, it is still the software/firmware on the cam itself that is running within the app.
Exactly it’s never addressed and they figure if we just ignore it will go away, but just remember in the event of a conflict with China, all of these Chinese devices will be a jump server used for attacks against critical infrastructure in the US. Meanwhile we have fake accounts like “Dave” Chinese frontman pretending that everything is fine.
I am Middle Eastern and @dave27 is Chinese. If your concern is US security maybe you should stop buying Chinese cameras.
Should get rid of the iOS devices also.
I challenge anyone to find an electronic device that is 100% US designed, sourced, and constructed.
Even if they were, as if Google, Apple, Microsoft, etc are totally trustworthy. They’re more of a threat than some Chinese SOC manufacturer.
Yeah OK, if you don’t care about the issue quit reading the post, it’s that easy instead you have to feel like a big funny tough guy behind a keyboard. [Mod Edit]
I’m still waiting for the issues to be correct the firmware update they claim Fixed this issues doesn’t seem to be getting pushed out. Or chairman Mao has not yet authorized it. Better china will soon take back Taiwan and we will actually enforce not buying Chinese garbage going forward.
Chill, you’ll live longer ![]()
