Recording Lengths not uniform
I have that program and have used it a few times to join MP4 files, it worked great.
The question is will it work with the v4 cam files which appear to be using a fairly unusual audio CODEC (G.711, usually used for telephone calls).
V4 cameras do not record in MP4 format?
MP4 is just a container. You choose the video and audio formats you want to put in it. Looks like the v4 is using H.264 AVC (common) for video and PCM-ULAW G.711 for audio which is not common.
Ive been searching everywhere. Its very hard to find.
For the list file, how can I input the path of the file such as date of the WYZE folder ? Such as instead of the original
file ‘05.01_05.11.mp4’
file ‘05.11_06.00.mp4’
instead
file ‘C:\20250201\05.01_05.11.mp4’
file ‘C:\20250201\05.11_06.00.mp4’
and also is it POSSIBLE to make FFMPEG.exe to run faster ?
