Pan cam night vision stopped working. Any ideas on how to fix? Cam is up to date and disconnect from power source.
When you call up the individual camera’s live feed in portrait mode, there will be a crescent moon to the upper right of the live feed. Does that say off? If so, just touch it to get it back to ‘Auto’. That is pretty easy to accidentally touch, which can turn off your night vision.
If that doesn’t work, touch the settings gear icon above the crescent moon. Go into Advanced settings. There you will find the same “Auto” setting for Night Vision. Below that is a control to turn the Infrared lights on and off. Is that on?
FYI, I use to hit that little button alot until I figured out what it did. Why is it green? It’s almost invisible with my old eyes.
