Pan Cam Keeps turning on
After flashing the Pam Cam with the latest Firmware. Upon shutting down the camera with the App. The Camera turns it’s self back on again, The only way to turn if off is to remove power!
Which firmware version are you on? “Latest firmware” becomes subjective as a topic ages. It is also helpful if you state the app version and OS you are on. :slight_smile:
I am having the same problem. I shut both my pan cams off in the app. Then several minutes to about 15 minutes later, I see that they are on and tracking my as I walk by. I’ve restarted the cameras. Is there any fix for this?
