Outdoor Plug usage history should not reset on the first of the month
Ah! I was just playing around with a Wyze Python SDK that’s available online and the full electricity usage history is available through the SDK. I was able to get my full usage timeline from first plugging in the device. Really neat. Also, suggests the information is not getting deleted, which was reaffirming. But would be great if this information was available through the app.
That’s amazing finding. Yes would be helpful if that data is viewable for normal users through app.
Good info — which SDK?
The one documented here. Let me know if you have any troubles!
Getting Started with Wyze SDK — Wyze SDK 1.10.0 documentation (wyze-sdk.readthedocs.io)
february 2024. I just submitted the same request and then found this post…clearly they haven’t implemented this super basic thing. I wanted to compare the usage with 2 weeks ago (since I changed a pump connected to the outlet) and…obviously there is no hystory because the month reset 5 days ago.
If they really don’t want to keep the history anywhere (like there is no space on a phone for a little bit of data?), provide the last 7 days or the last 30 instead of “week” and “month” which resets in the dumbest way at the beginning of the week/month
I only have two weeks of data being saved for the Wyze climate sensors with no way to export. This is not a hard update to make to both allow for additional data to be stored and to export to a .CSV. Can a Wyze admin comment on if this update is in the works?
That have it more basic than you want. In the end what can you do but wait and see.
Just take some screen shots and compare to that. Its not perfect but its good enough for a decent enough comparison.
This seems like absolutely basic functionality for anything that offers usage information. It’s useless without history. This is literally the entire reason I bought the thing. The fact that a request this essential has been ignored for three years now makes me think that this isn’t the company I want to buy from going forward…
Thanks for the info, I’m trying to do the same thing now. Do you have some example code for calling the “PlugElectricityConsumptionRecord” class?
I don’t see a clear relationship between the plug devices and this class, or where it expects the dictionary defined, if it only takes self at class init. Thanks for your help!
It’s 2025 now and I would really like the previous month’s total usage added to the viewable stats. I chose these outdoor plugs because they had the energy monitoring capability, but i can’t even get the total used for the previous month. I would’ve gone with another brand had I known this. Please make this update. Thanks.
I had the same complaint so I wrote a basic python program to return the usage based on a supplied date range. Still a work in progress but I figured I’d open source it if it helps others out too. GitHub - mattsbryson/wyze-power-util: Basic python program interfacing with Wyze-sdk (https://github.com/shauntarves/wyze-sdk) to return power usage based on date ranges.
I had the same thought about a year ago and worked up a little program to do the same thing. I didn’t know Python at the time (still kinda don’t) and I’m a trash programmer, but if you wanna take a look the repo is here:
mperry120/WyzeInterfacing: Program that provides limited interfacing with the Wyze servers
Yes, infuriating. Recently installed two of these, very disappointed with this product for this reason. Days reset at midnight, weeks overnight on Sat-Sunday, months at end of month. At minimum, app should show rolling 24 hours, 7 days, 30 days. Especially frustrating when trying to monitor from other time zones. Also disappointed you can’t set alerts for power exceeding X in Y time period. Looking for better options.
