Is it possible on an android phone to have the notification for person movement play a sound rather than vibrate? Is it possible to have different notification sounds for different cameras? I am trying to get rid of old security alarm system but have a comprehensive notification system in place.
I couldn’t find anything for your first question, but I did find this Wishlist topic. ![]()
Thank you. I think one of the things they should do soon is to develop a better more detailed user manual. That would answer a lot of questions.
Thanks again,
Paul
You could use a sense device like a contact or motion sensor and a separate sounding device like a chime with an Alexa or IFTTT routine to create a mobile alarm. I made the setup below in about 10 minutes and use it for alarms driven by both kinds of sensors with different ring patterns for each application.
Thanks.
Paul
Oops - meant to direct that reply to Paul…![]()
if you are android there is a work around.
I cant believe everyone forgot about this. @tomp @DreadPirateRush come on guys
this was my best how to.
Hey-you Android people! I did check it out in the IOS App Store but nothing turns up under Light Flow or Lightflow Shame- I was eager to play with it.
I didn’t forget your “best”. I’ve got it earmarked. I’m hopefully going to wind up with an Android device once this quarantine is over and I can travel.
Good work!
Oh, I remembered your how-to, I just didn’t think it covered person detection specific sounds. I guess I need to go re-read it, eh? ![]()
