Notification if smart bulb goes offline?
1st time with a wyze smart bulb user here coming from geeni and energizer smart bulbs. Their apps have notifications if they go offline. Does wyze have something similar? I own 6 wyze cams and trying to go full wyze to eliminate having to use so many apps. My ecosystem is alexa devices. Thanks for any advice, Mike
Unfortunately this is not currently an available feature. It has been tagged as in progress on the wishlist so it is most likely something being worked on at this time.
You can vote for it on the Wishlist here:
Thank You
