I just installed a new Wyze thermostat. I thought i had everything buttoned up. When I turned the AC back on, it runs for less than a second and shuts off. After a couple more seconds it will do it again. The thermostat itself will shut down, too. Is this a wiring issue or a capacitor somewhere?
Speadie would be the best to answer, but I suspect your 24v source voltage is dropping too low when the AC turns on and because of that the Wyze thermostat drops out which turns off the AC.
