Multipal Sprinkler Controllers
If I need 2 sprinkler controllers to handle my circuits, do I need 2 Sprinkler Plus Subscriptions?
Welcome to the Wyze community @XhixoBob!
Yes, one Sprinkler Plus subscription can only be used one controller.
You simply can’t have multiple controllers. From the Wyze Sprinkler Controller FAQ:
Does Wyze Sprinkler work with more than 8 zones?
No, Wyze Sprinkler is only compatible with up to 8 zones. Do not attempt to put multiple wires into one terminal or link two devices together.
Brlepage, if you know that the same Wyze account and one instance of the app on a smart phone can now control multiple sprinkler controllers, that’s great, but I haven’t seen that explicitly stated yet.
This answer is to a different question.
True, the instructions say to NOT put multiple valves on one zone.
The question asked about needing subscription for additional CONTROLLERS.
