Multi camera live view
Would like an interface that showed multiple live feeds instead of switching between each cam.
[Mod Edit]: Your post was merged to this category since it involves a question and not a request for a Product or Service enhancement by Wyze.
Hi @pablo_cc,
You can already view multiple live feeds from the Wyze app.
Click on the “+” sign in the upper left corner of the app home screen, select “Add Device Group” from the popup menu. Then select the type of device you want to group. If you select “Camera Group” you will be able to select the cameras you want to group. When this is done, the group will appear on the Home screen instead of the individual cams. Selecting this group will let you view multiple cams at one time, up to four per screen.
