Motion tagging not tagging
It seems in the last couple beta updates motion tagging isn’t working/tagging anything. The camera sends me notifications and works perfectly, I submitted a log in the app so the devs know. I’m on Android, S10.
Thanks for already sending in the logs! Can you confirm if you’ve tried adjusting the motion detection sensitivity settings and see if this has any impact on the performance?
I have also noticed this. It happened with the new camera beta firmware. The sensitivity hasn’t seemed to go anything. Sometimes it works great and other times I doesn’t tag it at all. But it still record the motion event. It knows there is motions but doesn’t tag the motion.
Can confirm I’ve tried that, it works sometimes doesn’t work other times.
