I i would like to see a Alexa enabled smart lock that will fit a security screen door with windows. It’s going to have to be a combination handle and dead bolt if it has to be larger or the inside unit could not be larger then a regular dead bolt.
Make sure you vote for your Wish Item. The system does not automatically add your vote
