How is it that my telephoto mailbox camera, my V3 driveway camera, my OG front yard camera and my pan V3 garage camera can all recognize a vehicle, yet my V2 flood light cam never does. (See attached) I’m forced to put it on all motion to get it to record anything including people. The detection zone filter is also not working as it consistently records the motion of the tree that is outside of the detection area but this seems to be an issue with most of my detection zones on all my cameras so let’s focus on people and vehicle recognition. Is the V2 floodlight device a dud? My other V2 floodlight also seems to have a hard time recognizing people on my deck. My V1 floodlights work great. I keep submitting video clips to Wyze but the algorithm doesn’t seem to be learning. Any suggestions?
I am having this exact same issue. Only motion detected, ever.
Every other camera I have continues to work well.
It’s a huge downgrade from the camera that was there previously.
I’m tempted to return it put my previous camera back up and get a cheap led flood light
I’m going to keep replying to this thread to keep it alive in the hope that someone has a setting that will fix this only motion issue.
Still nothing!
Another example. How is this tagged as motion and not registering as a pet and people???
All my V2 floodlight cams quit connecting to my subscription, so I have no AI notifications. All my other cams work. This is a two locations, two different routers. All quit. Worked with Customer Service 3 or 4 times. Nothing. They had me reset two of the cams, they will not reconnect, so they are useless now. I have tried loading the app on multiple android devices but that makes no difference either, Even down graded to an older app. Nope. They worked fine a couple days ago. They were working as motion cams without the subscription, now 2 are bricked. They said there is nothing to do but warranty, which will fix nothing.
After 6 or so reboots a (couple accidental yesterday) it detected a vehicle yesterday!!
I was shocked and have no idea what happened!
We’ll see if it keeps working…
Flood light literally just stopped detecting anything but motion yesterday…
Back to being a dumb camera with a light
