I created a basic device trigger for the motion sensor to turn on a Wyze bulb when I enter the room. Is it possible to schedule that rule so it only triggers after 7pm (without using IFTTT)?
Hello @alaputa37 and welcome to the community, what you are looking to do is not possible at the moment but is something they are looking at, here is a link to the topic I believe contains what you are looking for and also shows it is in-development.
No. I’ve turned in a wishlist to add that feature.
