How many can you have on one hub
Wyze doesn’t have a hub. Do you mean the Wyze sense bridge or your wifi router?
Wyze cameras, plugs and bulbs all connect to your wifi, the motion sensors and the contact sensors connect to the bridge (which is inserted into a Wyze cam), which has a Max of 100. The wifi Max is up to your router/access point.
And welcome to the forums!
@Omgitstony is correct. See support link below for the sense bridge Information:
