I am trying to hook up the thermostat and instructions doesn’t seems to be very helpful. I hooked up thermostat wiring fine but when I went to the circuit board to install C adaptor, the cables in the app doesn’t match with what i have.
I have split unit. Swapping W and G was easy since only 1 wire but when i went to Yellow, i have 2 wires in Y2 and one big green wire in C (see attached). That’s where I was lost. The instructions says to remove Y that is coming from thermostat. I saw G, Y, R splitting from a cable and so followed that Y (assuming that’s from thermostat) and then left the other Y on Y2 (attached). I left green C cable as-is since there were no instructions to remove it and then in the second empty C terminal, i hooked up C from the provided adaptor. Once the turned on the unit, the thermostat started making clicking noise. I had to undo everything and install the old thermostat back. But, this time also unit didn’t start and turns out i blew the fuse. Finally reset it but I back to square one. I have attached wiring of circuit board and any advice will be appreciated. If not I’ll have to return the thermostat.
but did u check in the wall to make sure it wasn’t wrapped around the cable?
Why should it matter? It was not in thermostat before do why now. Is it required?
So you do not need the adaptor from Wyze.
Very simple, pull the wires out from the hole in the wall until you see the brown sheath.
Check if you see the blue wire. If you do. You connect it to “C”.
Double check at your furnace that the blue is going into the knob with big green wire
If you worry wrong installation, check with a HVAC techn.
Yes, yes when i pulled brown sheath near the thermostat I see blue cable but I also see orange cable. Both blue and orange are not connected to any terminal. So, only W, Y, G, and R and connected. So, if I understand your instructions, I don’t need to do anything on the circuit board (no c adaptor needed) But, if connect blue to C then what about orange ?
yes, use the unused blue wire on the wyze tstat (connect it to C terminal), tell the app you have a C wire. It is already connected to C at the control board, and u wont need the adapter. The orange wire will stay unused.
I agree with Ken’s analysis. I had to do some similar troubleshooting when i did my install.
I have similar issues. My C board has so many wires connecting from the slots as highlighted. The current thermostat has only four wires but I can see the blue wire is unused. Should I go ahead and disregard connecting the C adaptor and just install the thermostat?[quote=“rhans, post:1, topic:172792, full:true”]
[/quote]
Lp
We need to see your board, not others.
Thermostat. Thanks
your wiring is pretty straightforward. If installing the C wire adapter, just add the C wire from the adapter to the C terminal on the control board (it’s ok to have multiple wires on it),
It does look like there’s unused wires in your cable that you could use for C instead of installing the adpater
Thanks, so should i just disregard installing it if its less work for me or go ahead and must install it? Thanks again.
if u have unused wires to connect to C, I would go that route…no need for the adapter if u have extra wires
You have used orange and blue wires.
Strip at thermostat. Cinnect to C.
Find the other end inside furnace. Connect to C.
Blue is good color.
