Had someone break property at my place of residence so checking back from what the notification told me it took me 45 minutes+ to get to the correct time stamp on my video because the green-bar does not work AT ALL in any shape or form to bring me to the correct time in playback. Whatever time I select on the green bar or selected time is irrelevant to where it takes me with the exception that if I rewind it rewinds etc. I can move back and forth but with no accurate stop time. It just jumps all over the place until I get close enough to watch it through to the desired time.
Someone else said something similar to this recently. This is not my experience on the iPhone, is it yours? I see you are using both.
The last person who reported this did not follow up with any specifics so we can narrow down whether this is a bug, or your environment. So tell us something about your situation: On what operating system are you experiencing this? What class of memory card you are using, what type of router you are using (like is it a WRT54G or equivalent 802.11g router), and how old is your device? It should normally only take a few seconds for what you have dialed up to start playing. No way should it take 45 minutes to find what you are looking for.
@strangenamemedia. This issue has been brought up before on viewing playback. This might help some.
But it would be REAL helpful to be able to enter a time and jump to it.
There’s probably something to vote for in #wishlist.
For the curious mind, you can search #wishlist and #roadmap easily using these links. Once you limit the search to the category, it is very easy to find what you’re looking for…
Search Wishlist (enter your search word/s after #wishlist in the search box)
Search Roadmap (enter your search word/s after #roadmap in the search box)
Also please read through How to Use the Wishlist.
