Firmware upgrade failure - pan cam
Installed brand new pan cam with 4.10.0.225 firmware, camera worked but upgrade to 4.10.6.156 failed, and now solid yellow light, tried both factory reset as well as power on/off and does not work at all.
Just to clarify, you said power on/off and factory reset. To be sure we are on the same page, are these what you did?:
Power Cycling
Factory Reset
If so, you might have to manually flash to an earlier firmware. Info here:
ManuallyFlash Firmware
How to Find Firmware
Yes I guess, gotta find a micro sd card, thanks
