Filter, sort and delete events by length of event
I would like
  • A way to filter events by length.
  • A way to sort events by length.
  • The ability to select the sorted events.
  • The ability to delete the selected and ordered events.
This is because I have clips as long as five minutes and want to remove them.
[Mod Edit]: Title, tags and request text modified to be more inclusive and to enhance search clarity.
Filter by event video length
It would be great to be able to filter video clips by the length of the clip.
For example:
View clips 0-10 seconds
View clips 10-30 seconds
View clips 30-60 seconds
View clips over 60 seconds
It would be great if WYZE could do this. Hopefully their programmers will get the ball rolling.
i would also like this feature for another reason, i want to filter out the shortest clips and only keep the long clips for bird watching. also this is such an easy thing to implement and is expected of any data list.
