I purchased a Wyze Pan Can and a Wyze 32GB SD card. I set it up for continuous HD recording on local storage. When i take the sd card out and insert it into my PC, I noticed the continuous recording only saves in 1 minute files. So recording for 2 hours saved in 120 1 minute files. Is there a way to change this so it saves in 1 120 minute file? I do video editing and 120 files is a lot to deal with.
Hello @jzeller3732 and welcome to the community.
No there is not a way to do this natively in the camera. The only option would be using a join program on your computer.
Thank you for the response!
Do you know if there is any frames lost from 1 file to the next?
As far as I am aware there are not
