I am running 4.9.6.224…on V2
Anyone notice a few of their cameras with a clock that is running one hour fast? It doesn’t appear there is a manual way to override and configure correct time. Not all of them just a couple of mine.
Yes, I saw this last week. I got it to fix itself, but I can’t remember exactly what I did to fix it. I think I just told it to sync time again, maybe reboot. It has to do with Daylight Savings. It didn’t update when the rest did. I’m pretty sure you just go to:
Settings - Advanced Settings - Sync Time - Sync
and it should update correctly after that. I think if I did anything more it would’ve stood out as different that I expected and I would’ve posted it on here. Since I didn’t I’m 99% sure that’s all it took.
