Can't view event
I have cam plus lite, and every so often I’ll have a recorded event clip that is unclickable. I can’t do anything with it, can’t check it’s checkbox to delete it, can’t view it, nothing. No idea why it’s happening or how to report it. There doesn’t seem to be any real pattern other than maybe it happens more often to the first clip on the hour, and maybe it is more likely to happen if there was only one clip recorded in that hour.
