Can thermostat control two blower fan speeds? Our G wire calls for a blower fan from one speed tap and and another wire (orange if I recall correctly) calls for a blower fan from another speed tap.
With lower fan speed we get better humidity control and with other better cooling. If wyze thermostat could switch between the two, is there a way to specify the usage for second speed?
Our original thermostat was semi programmable for lower blower speed initially (humidity control) and higher speed later for better cooling. When wyze was installed it was recommended to leave second fan speed wire off.
