Camera Zoom Lock/Save/Record
I would like the ability to lock or save a zoom when opening the app until cleared. ( similar to Nest’s enhance function).
As an example, I have a cam in the corner of my child’s bedroom. I really only use this cam to check on nap time so the ability to have the stream focused on the bed would be great!
Obviously, on the phone app it is not hard to just pinch to zoom to the bed. However, I am thinking ahead to when we have the ability to cast the stream to a TV or a hub. Pinching to zoom will no longer be an option and a zoomed out view of the bedroom will be largely useless in my use case. If I could have the stream zoom locked on the bed this would be way more convenient!
Thanks
A post was split to a new topic: Toggle Automatic Camera Position
Please add a feature that will allow camera to stay zoomed and focused. The Nest camera has this feature and I don’t see why it is not a priority for Wyze.
Thank you.
Hello
It would be nice to be able zoom camera position as a default position. Especially for Pan presets
I would really like a zoom lock feature. I’m currently using a old phone as camera and it can do this with the app I am using. The only problem with that is the camera is poor. Decided to give one of my wyze cams a try but the zoom doesn’t stick.
Has this been addressed with the Outdoor Cam? I’ve been working on the detection settings as well as notifications. I can’t figure out if it can be done. It does it on the Cam Pan.
This has not been addressed and is still an issue.
Would love to have a Digital Zoom feature for my Waze Cam 3 used at monitoring a bird’s nest in a bush. The movement of the bush from any type of breeze will overwhelms the low bitrate and I just get a mostly blurred video. Zooming into the nest and discarding the reset of the image should improve the limited bit rate. Please make digital Zoom available.
I agree. I was wanting this rearrangements same reason. I have a nest of my front porch plus I like to watch the deer in my back yard. I have cameras in both places but, a zoom feature would be great and allow for motion detection on the zoomed in area.
I agree. I have a baby who has a very rare disorder. She has a brain disorder that causes seizures day and night. I use the cam to record and keep records of her seizure activity. I need to be able to zoom in to see exactly what she’s doing during each seizure. She has every type of seizure that exists because her disorder is a malformation in the frontal lobe of her brain. It’s very important that I can look closely at exactly what she’s doing during each one. I could really really use a better zoom feature on the wyze cam v3.
As a workaround, you can double tap on the point of the view, and it will center that point and maximize the zoom.
I know you want something more automated, but this is the closest thing I can think of right now.
Of course when I get around to it and re-familiarize myself with python, use the kroo thing and replace the Wyze app altogether and have all these nifty features.
Yep, real soon now, ha ha.
Wish for the ability to record at a custom zoom level
Would be great if the app had the option to record at a customized zoom level
I, too, am using Wyze Cams for backyard wildlife because they are less expensive. I have been learning how to better use the features and understand the algorithms used. There is a lot that cam be modified, inexpensively, to make them better suited for close use. This could be a whole new market for Wyze. There is enough demand in these forums. They could have both Security cameras and Wildlife cameras. I am presently using 2 Wyze Cam Outdoor and 1 V3 regularly. Some of my videos can be seen in the “Wyze Cam Outdoor on a Birdfeeder” conversation thread. You can also see Wyze camera video footage on my YouTube site “Keith Dael”.
Hopefully they will add the option. Maybe a drop down for 2x,3x,4x zoom would be a good starting point
Good luck!
A zoom lock would be awesome. I like how wide the viewing range is, but where I’m using my camera I really only need a certain area under surveillance and it’s kinda a pita having to zoom into each event to see what I’m looking for.
@jennielowery,
Without knowing what type of camera you are referencing or what you are trying to capture --a couple of ideas.
The OG-T with its 3x optical lens would allow you to get really close at the expense of Field of View. I use one in my living room that is trained at the top of the living room door. It’s about 20 ft away and does a good job identifying who is coming in the door.
Another idea - - if the object is moving about, is to explore a Pan Scan V3.
I’m not sure if either of these ideas will help your use case-but you never know.
No, I mean the view stays locked at the zoom you want. I can zoom in anytime I want but once you close the app it goes back to its normal view.
It would be great if the camera view stayed where you put it, so the events recorded were at that zoomed view not the normal wide view.
I have 3 OG’s and a V3
Understood. I’m not aware of any wyze camera that will do this.
This is already on the wishlist. All we can do is “Vote” at the top of this thread.
Set digital zoom as a zone in Wyze app
Hello Support,
I just set up a Wyze Cam PTZ V3 and I’m using Android app version 3.14.0.807. Would it be possible to add the ability to lock a zoom position as a zone for each camera? I have one camera that I want to lock a zoom position so I can permanently capture details on that camera on the livestream. I searched this forum for a similar question and found one from 2018 but it was referencing the V2 and it’s marked as “maybe later”. I know the zoom feature is purely digital so would need to be done in the app as opposed to the camera.
[Mod Note]: Your topic and associated replies were merged to this Wishlist request for consistency in grouping similar requests and for better visibility to Wyze. Please remember to scroll up to the top and click the VOTE button to show your support.
Welcome to the Forum, @TechGirl00! :wave:
Please be aware that the Forum is primarily a user-to-user support community, with no guarantee that anyone from Wyze will read or reply to a given topic or post, and we are not official Wyze Support. Having said that, we volunteers do try to be helpful, so I’d like to follow up on a couple of things in your post:
Are you asking about setting a particular zoom level on a given Waypoint, or are you looking for a zoom feature as an addition to a Detection Zone, or are you requesting something else? I’m trying to understand the suggestion here.
If you saw something tagged Wishlist > Maybe Later, then that indicates you looked in the Wishlist. :+1:
What’s the particular post you mentioned? A link would be helpful. When I did Wishlist searches about setting or locking a zoom position, I was finding topics like these:
I didn’t see anything in those specific to Cam Pan v2, though, so I think you probably mean something else.
