I can view my Battery Cam Pro’s with Firefox, but my new Solar Cam Pan’s require Chrome? Why is that? I prefer Firefox over Chrome.
SJ
Because Firefox doesn’t include the necessary decoder license, and Chrome does.
As far as I know newer Firefox versions on Windows can play H.265 when the PC has hardware decoding, but it depends on the HEVC Video Extensions from the Microsoft Store being installed. If you’re on Windows it might be worth installing that, updating Firefox, and trying again. It’s possible the Wyze site still only allows Chrome for these cams though, in which case keeping Chrome around just for that page is the easy way out.
Sort of. It requires Web View to “think” that you’re using Chrome, as noted here and elsewhere regarding Cam Pan v4:
I haven’t been able to do the same thing using Firefox in the past, but I haven’t tried recently. I kind of gave up on using Web View in Firefox quite a while ago because I could never get it to stream Cam OGs.
That’s a decision Wyze has made[1][2], so you’d have to ask them. ![]()
I realize that’s not a satisfying answer at all. There was a lot of consternation with the Google Chrome requirement for Cam Pan v4 after that one launched, and I don’t anticipate that changing any time soon, but I’d personally like to see Wyze be more flexible and standards compliant, like not using UA sniffing (which MDN seems to indicate is a bad idea for determining how a server is going to present information to a given browser) and getting rid of the
stepper arrows that they use as a spinbutton for entering the authentication code during login, because they’ve designated that field as input type="number", which seems like a poor decision from an accessibility standpoint, and that’s been causing other headaches for users for quite some time. ![]()
