Hello, when loading cams in a group are they loaded at full resolution or is the resolution set to a lower option?
A Wyze engineer chimed in with that answer about 4 years ago… reduced down to 360p each in grouped display. I’ll try to find the post…
Found it:
Good question. I did not know that but understand it. I guess 4 v4 cameras are throttled the same?
Thank you! I appreciate it!
Yes, 2, 3, 4 all throttled the same in a group. Note that this does not change your single cam view preference/setting.
