I have in the past, was just sharing information as per the post. I’ll troubleshoot further later.
Hello,did they find a fix? I am having the same problem for 5 days now but only on the doorbell,the other cameras are fine.Thanks for any assist
Welcome to the Forum, @firstknight! ![]()
From your post, I’m having difficulty discerning what potential fix you’re asking about and what problem you’re experiencing. As this is an older topic, if you’re having a specific issue then I wonder if creating a new topic with a detailed description of that might help you to attract the assistance you’re seeking.
appolagies,I thought it was a thread just for the error 20004 on the wise doorbell v2
No apology is necessary! ![]()
Thanks for replying with more detail. I’m not sure what’s at the root of that error message, though I’ve seen other community members report it recently. I haven’t ever seen an official explanation for that particular error code, and the Help Center isn’t providing me an answer.
If you haven’t already done so, I’d suggest creating a log the next time you’re able to reproduce the error and then following that up with a Support ticket.
This is how I prefer to submit tickets (you can tap or click to expand this):
- Visit the Help Center: https://go.wyze.com/help[1]
- Click into the “AI-powered search” box in the middle of the page and enter
create ticket. - Click Yes, that is correct.
Repeat Step #3. (
UGH!
)- Click No, I do not like chatbots.
- Click This is about a product.*
- Click Other.*
- Click Create Ticket
- Enter your contact details and a brief issue description (include a Log ID if you have one) and click Submit.
* Make your own appropriate/relevant choices here.[2]
It doesn’t really matter how brief the description is. Wyze’s system will generate an e-mail message to you automatically with a Wyze Ticket number, and you can just reply to that message from your e-mail client and add as much detail as you want.
I suspect Wyze has made some back-end changes that are causing this issue, though that’s only a guess on my part based on previous observations. Letting them know via logs/tickets that this continues to be a problem is probably a good way to have this on their radar and get them to address it.
