when using find device or find band, it can be difficult finding the other if media volume is low/off, or cause the band vibration can’t be heard if on something soft.
when find device is selected on band, display a solid hot/cold color on the screen to help indicate if you’re close or not. Blue/cold = weaker signal, red/hot = stronger signal. Tap color screen to ring/vibrate other device.
Similar control in app.
this can help narrow search before ringing the device
