So I changed the password two separate times and it still says the password is incorrect but will log me into Desktop. Has anyone else experienced this?
Login problems are always a possible issue with apps. I love when it happens and then devs say there’s no problem and then fix it months later… or don’t realize it even when app reviewers are saying there’s a problem.
The best you can probably do is going into the app’s Android settings and clear data then try logging in again. You can alternatively uninstall/reinstall the app (they both do the same thing so clear data or uninstall/reinstall). See if it works after that. If not then try again in x hours, x days, 1 week, and if still not, then wait for updates.
Typically, there’s not anything else to do. Not unless its an actual problem on your side of things.
