A phone widget that allows you to scroll thru cams, on off radio button, and mini screen would be so awesome!
Android 8.0
Thanks!
Thanks for the information, I do recommend that you make a roadmap topic for this idea since it is only currently requested for iOS.
I’m getting the following message when trying to add Road map category : you are not permitted to use the requested resources.
Do I need to start a new topic? Thanks
Yes @amhatfield11, you have to create a new topic with the idea you have. As a tip make sure it’s detailed so more people can fully understand it.
