1, pay attention to check whether the machine can not reach the cleaning area due to obstacles or room door closed
Check whether the equipment is not cleaned completely due to the change of the environment of the items in the swept area
Check whether some areas fail to be cleaned due to changes in virtual wall Settings
If a single room is missing scanning, please remind the user whether the back door of the machine construction is closed and cannot enter the room due to the change of the opening and closing door, and the cleaning is not completed
When cleaning the machine, please pay attention to avoid direct sunlight from the machine, which will affect the radar scan and map construction. You can communicate to change the time period to try cleaning
