I have solar cam. Cant find where to insert sd card
There is no such thing as a solar cam.
If you bought the bundle of the solar panel and the battery cam pro, I believe the SD card slot is in the same place as the battery but not positive. Did it not come with a diagram showing you what each part of the cam is?
It is shown in this pic, right above where the battery goes. If you have a different cam model, most of those have a rubber cover over the slot that you pop open, put in the sd card, then close again.
