So, here is my mailbox update… My WyzeCam died after nearly two years of punishment in FL weather. Pretty admirable considering it was not designed to be used outside. I had originally designed the solar electrical system to power a single camera with an AGM battery. When the camera died, I decided to upgrade the battery to LifePo4 to get nearly double the useable capacity. I had to change my charge controller to accommodate the new battery as well. Since I doubled my capacity, I decided to add an additional camera so I can see both directions up and down my street now. I also moved the cameras from the front to the back so it looks a bit better from the street view.
I am testing now to determine if I have enough capacity for a day or two of bad weather, etc. If not, I am contemplating surrounding it with a plant bed and integrating two additional ground mounted 25 watt panels hidden somewhat by small plants, etc… This will allow for a quicker charge/recovery time when I have bad weather for a few days. I just installed the new battery, etc. last night so i still have some wire routing from the cameras to clean up and I’m going to put a slat over them to protect them from the harsh FL
sun and rain.It has been an experience and I have loved the capability to use the camera at street level. My neighbor even asked me to turn it on his house when he had a roof installed. I time lapsed a video for him so he could see the progress when he was working. As I continue to upgrade, Ill post here in case anyone is interested or has questions.
