Is it possible to control/decrease sounds and announcements that Sense Hub produces? For example, I have a rule to turn monitoring off at specific time, when this happens, Hub announces “Disarmed”. Is it possible to disable this announcement? Similarly, when I open one of the windows with an attached Sensor, there is a ping that happens on the Hub. It becomes a bit annoying over time.
I can’t seem to find a way to control all these sounds. Is there a way to do it?
You can set the volume by opening the hub and selecting low, medium or high. For the pings on the sensor opening, that is controlled by the TUNE setting in HMS. You can disable the pings but not any announcements.
And some other that you that opens that window gains a hint that something related to the window triggered that ping. Then they go looking and Ta-DAAA! easy to unplug it when found, eh?
