Second Home - How to set up 2nd Home Home Monitoring In Same App Log In
Hi.
I have the Home Monitoring system on my wyze app but I wanted to add more than 1 home into it. Is there a good work around this issue?
I don’t want to have 2+ logins just to view the hub/keypad/door sensors.
Second Wyze account.
Unfortunately, there is a current limitation of only one HMS Subscription per Wyze Account. And, you can only be logged into one Wyze account at a time so the only push notifications you will receive are those from the account the App is logged into when last closed.
Noonlight, however, operates via SMS and Phone Call, so there isn’t a problem there.
That is the only option.
Is it possible to have the second home account on a separate device (iPhone for one and an iPad for the other house) and leave them each logged in?
I’m also interested in folks’ experiences with using TWO ACCOUNTS in order to be able to use Home Monitoring in two locations.
HMS isn’t really designed for more than one home. You can have more, but it requires a separate account/login for each one. Not sure how or if NoonLight tracks cell phones by account, but you need one for messages and contact in the event of an alarm.
