Really, I appreciate that you’re trying to be helpful, but please understand that I do have a solid grasp of my application and requirements and have already weighed these things on balance. For my use, smaller file sizes do matter for multiple reasons and the lower bit rate video is completely acceptable. Things that may be non-issues for your use are issues for mine.
I’m using these cameras as standalone field recorders with continuous SD-card recording powered by battery banks. The uploads I mentioned are not to Wyze…I’m not using the subscription services, they’re to my own storage for client access. Both the time it takes uploading and storage used matter in that workflow. And even the lowest bit rate Wyze recording is still way better than the 480i ~300 kb/s systems being replaced. In fact, this is often intentionally a “low-res” application, because being able to resolve personally identifying details is sometimes undesirable (think having to blur a face that ends up in a shot)
As to which model I have, the reason I came here was to try to understand some unexpected behaviors of the WYZECGSD (2025) Cam OG model and hopefully find out whether other users had seen the same thing or found solutions. Along the way, I also discovered some unexpected behavior with the earlier WYZECGS model.
Regarding which model is doing what, the older WYZECGS model ONLY records to the SD card at two bit rate levels.
High when set to either 360p OR HD
Medium when set to SD
That behavior does not match Wyze’s own article describing the feature (screenshot below). It will not record to the lowest bit rate as it should when live view is set to HD.
The newer WYZECGSD (2025) model does record at the three bit rate levels, but continuous recording reliability makes it unusable for my application and I’ve already deleted them from the app and am returning the ones I can. But what I have
High when set to 360p
Low when set to HD
At this point I can’t verify the 2025 model order with complete certainty anymore, but I’m pretty sure of it because ironically, before I found Wyze’s article showing the logic was inverted, I was selecting 360p chasing the smallest files, and every recording I gathered in testing was highest bit rate files except for one card that has the lowest bit rate files, which I assume was a cam accidentally not changed to 360p.
