Simple
#1
I had a WCO (out of warranty) die on me. I picked up replacement that is likely new “old stock” from eBay.
This may be a question for support but does anyone know the latest firmware I can manually flash to connect to the latest WCO Base Station firmware
or will current WCO Base Station beta firmware see any old firmware up to and including RTM and allow for firmware updates?
Thanks!
Simple
#2
All went well… connected to base and after a few firmware updates later up-to-date
If it is a V1 WOC, then it will get that firmware, and if it is a V2 WOC it will get that firmware.
system
Closed
#4
