Replacement Battery Straps for Wyze Car
"This question pertains to the Wyze Car. I have broken one of the rubber straps that hold the battery pack. Can I purchase a replacement pair? "
Hi @willjam513.
I did some searching and couldn’t find an exact band and configuration of the Wyze Car Battery straps, but, I did find these bands
They are .5 in width like the original bands. You could cut them to length (4in and 5/8) and center punch (probably with a hole punch) as a replacement.
You could also contact Wyze Support and see if they have replacements?
Thanks for the input. I will try Wyze support and see if I can get replacements. But getting to them can be a pain. I think your suggestion probably is better.
How about velcro straps
bicycle inner tubes might be similar. One of my straps broke at the hole at end of strap.
