Quick question regarding video quality
In the Cam Pan (v2), when selecting video quality (HD/SD/360), does that just apply to streaming video? In other words, does the setting also apply to the quality at which video is recorded to the SD card? Or both?
Jeff
That applies globally, to all recording, SD card, and live view.
Thanks for that. So, theoretically, if I set a camera to SD (or even 360) versus HD, I should be able to record longer on the SD card, correct?
The reason I ask is because I have a camera in an area where higher definition is not important, and I just want to maximize how the recorded video history on the SD card.
SD setting will essentially double your time capacity on your card (give or take a margin) compared to HD recording.
For example, on a 32GB card recording continuous, HD = about 3.5 days (+/-); SD = about 7 days (+/-)
You mentioned 360p. Here is a statement by Wyze:
