Problem Connecting to Server on iPhone - Not able to login. I deleted the app and installed it back. Reset the password. Still no luck. I am using iphone 14 Promax, iOS version - 16.5.1
Could you send a screenshot of the error message your receiving?
What if you login on the website, does that work?
Have you tried a different network and disabled your vpn?
I turned off VPN and tried it again and it worked!!! Thanks
