I feel that the two issues are related because once the camera has crept upward, I can’t lower it even manually because I am told I have reached the camera limit. If I go all the way to the right and left then it rests but the original waypoint is still gone and I have to redo it. It seems that maybe the camera is forgetting its lower limit and that’s why it creeps up.
I do this once a week at least because I need the camera to stay stationary unless it detects movement. I contacted tech support and their brilliant solution was “have you done a factory reset?” and even though I’ve heard this complaint from many other V3 Cam users and I have 2 cameras that have the same problem, support believes it’s an issue on my end.
Is there a fix for this in the works?
