Pan Cam V3 detection zones
I have 3 flat Wyze cables running through a single window like that (next to each other, not on top of each other obviously). As long as you aren’t opening and shutting the window a lot and are careful to close it gently the first time (to shape the wires) it is surprising how well they squeeze through.
But if it was opened and shut a lot I wouldn’t be surprised if they wore through relatively quickly.
My house has white aluminum siding so hiding the wires hasn’t been too tough, I have small white nail in clips that fit into the small weep holes that are in the bottom edges of the siding, and I mount the cams near a corner where they can be put into the corner channel that the siding slides into and hidden in there.
The windows make like s suction sound when I open them because they fit real tight in the groove. So yeah, it is a super tight fit.
My siding is a light green and it’s over 20 years old. It’s in good shape but it’s not white and apparently impossible to color match.
I tried putting the cable inside the corner clip but it would not stay. It was also re-done the other day and a bit cold outside. I will check to see if I can get it to fit in there good when it gets warmer out.
The one on the front deck goes along the edge of the window shutters (fake, just for looks) so there is nothing to put the cable into or behind, and it is about 3 ft from the front door so I want to hide it well enough so people can’t see it easy. The cable along the deck is hidden by the edge of the deck as it is that tight up against the house that it won’t fall down. Right now it is pretty hidden unless you look for it, even though people will see the camera as they approach the front door.
You can give it a test in the window, just don’t force it too hard. Mine seals very tight and can even lock shut with the wires running through, and they’re bent several times to fit the contours of the complex seal. May not work in your case, but just an option to keep in mind.
My siding is probably 40 years old at this point, if you wipe your finger across it, the white comes off a bit. But under each lap there is a small drain hole every so many feet and it is perfect for tacking stuff into (obviously don’t block them all but there’s plenty of them). So even if the window isn’t an option, that might be. There is also a cheap tool that you can slide under where each section of siding snaps together to pull it out, then use it to pull it back over, I’ve tucked wires in behind for other stuff before too.
Each setup is different but the corner channels on my house are perfect, I can fit the wires in there and even a small nail in clip to hold them in place and they’re totally out of sight, so all my cams are either directly outside a window or near one of those corner channels. Barely any wire visible anywhere.
One perk to living in an HOA that doesn’t allow outside cameras is I am forced to put all my exterior facing cameras, inside windows looking out. Inside the windows and inside my house provided ample outlets, and keeps the cameras nice and warm and protected. That may be an option for you also to maiunt cameras inside looking out. If you do this. Just know that you can’t have the IR lights enabled. And depending on the angle of the camera may have to deal with some reflections from inside.
Works great for me since 2019.
Also easier to hook up to UPS.
No HOA, yet.
