I was just about to install my new v3 and as I turned it over to pull the stand away from it, I heard a rattling sound. The sound isn’t coming from the speaker (it’s not even plugged into power). It sounds like there is something loose and rolling around inside the casing. While I have 2 other v3 cams that I bought, I didn’t notice any sounds from them and unfortunately they aren’t where I am so I can’t check.
Once plugged in, the cam appears to function fine, but I’m concerned that there is something defective and now is the time to exchange it while I’m under in the 30 day return window.
Is this normal or does it sound defective?
