Hi, My old Wyze thermostat failed and I purchased a new Wyze thermostat. What is the easiest way to pair the new one? I want to maintain all the settings in the old one. Will it automatically pair when I turn it on the first time or do I need to go through setup? Should I delete the old one off the app?
Thanks in Advance
There isn’t an easy way.
Because it is a different device with a new MAC Address, the App will see it as a brand new device with no previous settings, completely separate from the first.
There is no way to port settings from one device to another.
You will need to do a complete new setup and reprogram on the new one. The old one can be deleted from the App.
Thanks, not the answer I wanted, but no big deal. Should I delete the old one before I start?
If you are going to name it the same thing, yes.
