Before posting in the #wishlist category, we ask that you do a quick search to make sure that the topic is not already there. This saves our moderators time in not having to merge submissions. Just search for a one or two key words of your proposed topic. If it’s there, it should pop up, and then you can vote and add comments. There is no need to search each subcategory of the #wishlist separately. One search will cover the main category and all subcategories.
There are four ways to search in a specific category:
Use this link: Search in Wishlist and add your search term(s) in the box.
If you are viewing the topic list within a category, when you click the search icon
click the option to search only in that category:
From any forum screen, click the search icon
and then the “advanced search” button
at the right end of the search box. This will take you to the Advanced Search screen where you can choose a category to search (and several other options): -
In any search field (popup or advanced), you may type “#wishlist” or “#category-name” to limit your search to that category.
