I wish I had thought of this, but I did see it somewhere on here before. Home Depot has small metal bird feeders that hole the V2 cam like it was made for it. Just remove the “window” trim and plexiglass, and the magnet base holds the cam in place. Set or hang it under your porch (out of the weather) and our outside cam is disguised.
C’mon - give a link for the lazy!! ![]()
Good find.
Is it this one?
https://www.homedepot.com/p/Perky-Pet-Gray-and-Lime-Seed-Duo-Bird-Feeder-420/300456891
Love it, very clever.![]()
Yes, that is the one
Hello. Do you think if I would be able to fit the wyze cam outdoor camera in the bird feeder?
2 years later is an extreme response, lol. But try a V3 instead.
