Fullscreen crashes app because of font size
Basically the title. If I go into the display settings and change the system font size back to normal fullscreen works. If it’s set to anything smaller the app crashes and won’t let you view fullscreen.
Insanely annoying.
Try going to Wyze app Home > Account > App Settings > Enable Hardware Decoder.
If it is toggled off, toggle on. If it is toggled on, toggle off. One of those two settings should work for your viewing device.
If neither works, please state your app version number, phone model/type and OS version so other users who have experienced the same issue can help.
I tried that setting turned off and on. Neither changed the problem.
Phone: Pixel 7
App version 2.45.0 (342)
Android 14 ( did the same thing on Android 13)
Sorry… not familiar with Pixel UI. It sounds like there’s a disconnect with the Android fullscreen mode. I don’t know where the setting to check is under Pixel UI, but most Android UIs locate it in Settings > Display > Full screen apps > Wyze > “This app is optimized to run in full screen”. Some UIs lock the setting down, but you can get to it in Developer Mode also if the app isn’t already fullscreen-optimized for your phone. There are many Pixel users on this forum (probably not running beta 14) including several @Mavens … hopefully a Pixel user will chime in here.
I wish I could help, I don’t have an old pixel phone anymore to test this out with.
Yeah Pixels don’t have that setting as far as I know. I think it’s a Samsung thing.
